Home › Forums › Product Discussion & Questions › BeoLab › BeoLab 3 no light
- This topic has 1 reply, 2 voices, and was last updated 1 year, 9 months ago by
Steve Gill.
21 May 2024 at 12:22 #55806
Hans Peter
BRONZE MemberHello everyone,
my BeoLab 3 no longer works. A check revealed that the fuse and two SMD capacitors in the power supply were defective. Unfortunately I can only find the block diagram on the internet. Does anyone have the circuit diagram for the power supply or knows the values of the SMD capacitors?
Thank you 🙂
Greetings22 June 2024 at 14:45 #56924Steve Gill
BRONZE MemberIf you are referring to the SMD Capacitors around D501 they are 0.01uF C0G
