Home › Forums › Product Discussion & Questions › BeoLab › Beolab 28 + 19 setup via Core/Transmitter
- This topic has 2 replies, 3 voices, and was last updated 10 months ago by
trackbeo.
4 June 2025 at 03:31 #66189
Eric Stone
BRONZE MemberHello everyone. I previously posted about this setup with the eclipse and I ended up getting rid of the eclipse. It had its own set of issues but it was able to properly filter the bass between the 28s and 19.
I Figured the core and transmitter could do the same since it seems pretty simple and both the app and the sub itself have filtering on it.
the setup plays but it sounds nothing like it did when the eclipse was controlling it. The bass feels empty and off in some way.
here’s the thing, if I have the filter set to off on the sub, and set to 20hz in the app, play a 40hz tone, the sub still plays. So it would seem the app filtering isn’t working.
if I set the filter on the sub to on, and set it to 40hz, then play a 50hz tone, again the sub still plays something.
I have no idea what is going on, and of course bang and olufsen tech support can’t help. Does anyone here have any experience getting the filtering on the core or the 19 to work? Not sure if I should post this in the core section…
6 June 2025 at 14:18 #66216 B&O OrlandoBRONZE MemberWhich transmitter are you using? Are all three speakers using it? Are some hardwired and others wireless?
8 June 2025 at 03:19 #66237 trackbeoBRONZE MemberThe traditional fix to “bass feels empty” is to flip the phase switch and see if that improves it.
Note this is not the true answer to your question, nor to any delays canceling out certain bass frequencies, to which B&O ORL alludes. But it may give a better-sounding few days while you work on the issue. -
