Home › Forums › Product Discussion & Questions › BeoLab › Beolab 2000 vs 8000 Woofer…
- This topic has 2 replies, 2 voices, and was last updated 1 year, 1 month ago by
matador.
7 February 2025 at 15:24 #63522
matadorModeratorHi alls,
Beolab 2000 woofer looks like a lot like a 8000 woofer.
SM says they have different part number but I’d like to know if they’re is any hint about if they will fit or not.I know changing a driver involves a calibration process, but right know I have a scratching driver and it is worst than anything else.
Thanks.
7 February 2025 at 16:33 #63526LeHe
BRONZE MemberEven if it would really fit with a few adjustments, then still, the power range and characteristic of the speakers is to different.
In power alone I think it is a factor 1:4 (25 to 100 Watts)
Beolab 8000 wil also sound very different based on yield and one time the volume level too high at the Beolab 8000 and the Beolab 2000 speaker also runs out the coil, that the scratching more worst is then the old one.
Fitting is a matter of measuring or try on error, but the technical specs are to different.
7 February 2025 at 17:45 #63532 matadorModeratorThanks Leon, thats All I need.
