Home › Forums › Product Discussion & Questions › BeoLab › Beolab 2 NTC thermistor value
- This topic has 1 reply, 2 voices, and was last updated 8 months, 4 weeks ago by
Peter Fraser.
12 June 2025 at 21:33 #66328
axel73
GOLD MemberHello everyone,
I’ve just bought a knowingly non-working BL 2 (red LED) on internet:
When turning on my Beomaster 7000, the BL 2 LED briefly goes from red to green and back forever to red (with the clicking sound of a relay).
The Powerlink cable used for this setup was tested on my Beolab Penta and is working correctly.After opening the BL 2 I’ve discovered that the previous owner tried to replace the NTC thermistor screwed on the back of the woofer.
Since I’m not sure that it was done correctly, I would like to make sure that the right NTC thermistor was used.Could someone please tell me what should be the value of this NTC thermistor at room temperature (around 20°C)?
Thanks for your help.
Best regards,
Axel25 June 2025 at 14:48 #66645Peter Fraser
ModeratorHello Axel,
The NTC should read about 500KΩ at 23°C
PCB 48, NTC is still available as a new part if required.
Part Number 8100090You can purchase this part from Multicare.
Cost £4.57 + VAT + Shipping.You can contact Multicare here:
Contact at Multicare ElectronicsKind regards,
PeteSignature: Peter Fraser
Service Technician
Multicare Electronics -
