Home › Forums › General Discussion & Questions › General Discussion & Questions › Beolab 2 Highpass Filter in output?
- This topic has 2 replies, 2 voices, and was last updated 1 day, 21 hours ago by
Stan.
30 December 2025 at 13:25 #72198
spassmaker
BRONZE MemberHi dear Members
I’ve got a question about the Beolab 2 Subwoofer if there is a High Pass Filter in the Powerlink Outputs and what is the cutoff frequency.
In the service manual is a HPF shown but nothing about the cutoff frequency. So it would belong to the way you connect the speakers to the BL2 or direct to the Beomaster, what would be the right way?
The switches on the BL2 seem to work without any affect to the Powerlink outputs.
Maybe someone here has further information for us.
Wish you all a happy new year.
Kind regards
Christian
5 January 2026 at 17:11 #72363 spassmaker
BRONZE MemberReally no one?😔
5 January 2026 at 22:39 #72366Stan
BRONZE MemberAFAIK, there is a hpf in the output chain. Its cutoff depends on the setting of the 2nd switch (the 1st switch is for corner, wall, free placement and doesn’t impact the PL output, only the BL2 sound). This 2nd switch does impact the PL output on the BL2. I and many others have heard this with our ears (or perhaps we’ve all been tricked by the placebo) – read the old forum posts around the time the BL2 came out.
For music, it’s generally recommended to connect the BS2 to the source, and then the speakers to the BS2, and set this switch according to the speaker type to get the appropriate cutoff for the speaker. I believe the speaker assignments for each switch position are in the manual (but, of course, speakers created after the BL2 will not be there). I believe the switch position 1 is for the BS1, and 2 is for the BL8000s and a bunch of others (these are the two speaker types I’ve had connected to my BL2)… don’t recall which speakers are recommended for 3. There are only 3 settings.
In typical B&O fashion, the technical details are not published (perhaps in a service manual?).
For Home Theater, you generally do not connect your speakers to the BS2 so the audio engine can control each type of speaker individually.
