Home › Forums › Product Discussion & Questions › BeoLab › Beolab 14 Subwoofer Repair
- This topic has 2 replies, 1 voice, and was last updated 5 months, 3 weeks ago by
adyan.
3 October 2025 at 11:24 #70091
adyan
BRONZE MemberHello,
trying to repair a Beolab 14 subwoofer. Problem is, switches on for about 5 seconds but after the 5 seconds it switches off again. In this 5 seconds it seems that everything is working and there is sound from the woofer.
After reading the manual and checking everything I found that the NTC module has not the correct resistance of about 470kOhm (measures about 550 MOhm).
Is there someone who can supply a NTC module? Or is there another thing I can try to replace it?
thanks in advance, regards
4 October 2025 at 15:53 #70124adyan
BRONZE MemberHello,
beside of the NTC problem…
after further inspecting the mainboard I found there is a component missing, hopefully someone can point me in the right direction what is missing there or picture from this section.
You must be logged in to view attached files.4 October 2025 at 15:55 #70126 -
