Home › Forums › Product Discussion & Questions › BeoLab › Beolab 14 Sub – IC identification needed !
- This topic has 39 replies, 3 voices, and was last updated 5 months, 3 weeks ago by
adyan.
16 January 2025 at 19:42 #62810
Jonathan McCall
BRONZE MemberThanks – that’s interesting. Although I’m getting nothing.
Could be a dicky Powerlink cable, I’ll do a continuity test on it tomorrow.
Appreciate the help.
Jonny
16 January 2025 at 19:49 #62811Jacob Terp Christensen
BRONZE MemberSounds like a good idea.
I will try and see if I can get mine working in the weekend.
16 January 2025 at 20:49 #62812Jonathan McCall
BRONZE MemberGood luck – interestingly, I found a green micro switch tucked away on the ICE board. Tried pressing it with power off and with power on, but no change. Could be that it needs to be held in for a few seconds ?
Just surmising of course, but there must be a reason for it.
17 January 2025 at 11:14 #62822Jacob Terp Christensen
BRONZE MemberI don’t think it should be necessary to press a button. The button might be needed for service.
20 January 2025 at 11:35 #62918Jonathan McCall
BRONZE MemberAre you sorted Jacob ? Hopefully you’ve got it all working again.
20 January 2025 at 11:44 #62920Jacob Terp Christensen
BRONZE MemberI soldered the new IC, but when installing the boards, I managed to rip off a bi-amp IC, so I am now waiting for a replacement for that. When installing the boards, they have to be forced down on each side of this plastic extrusion (pic 1). This means that the components on pic 2 are prone to being ripped off. Bad design…
You must be logged in to view attached files.20 January 2025 at 11:59 #62924Jonathan McCall
BRONZE MemberWonder if that’s the same on the 14 ? Must admit, I didn’t seem to have any mounting issues.
How far apart are the 14 and S8 in terms of design, componentry etc ?
20 January 2025 at 12:06 #62925Jacob Terp Christensen
BRONZE MemberMy S8 is the earlier model, which should be identical to the 14’s. Do you have pictures of the mounting on yours? I believe they use the same ICEpower module and power supply.
20 January 2025 at 12:17 #62926Jonathan McCall
BRONZE MemberWill see if I can get some later.
20 January 2025 at 12:23 #62927Jacob Terp Christensen
BRONZE MemberThanks! Did you get yours to work?
24 January 2025 at 09:49 #63043Jacob Terp Christensen
BRONZE MemberJust an update,
Got the other IC soldered, and the sub assembled. Will be testing it today or tomorrow. Hopefully it won’t explode, in which case, you wont hear from me again 😀
24 January 2025 at 10:00 #63044Jonathan McCall
BRONZE MemberThanks for the update. My cable arrived from Steve along with helpful instructions on which of the 4 sockets to plug it in to. Turns out I was using all the wrong options.
Still doesn’t work.
Will hopefully be able to get some time on it at the weekend and see if that little green micro switch needs pressing.
Good luck !
28 January 2025 at 19:52 #63170Jacob Terp Christensen
BRONZE MemberHey, did you get time to look at it? I finally got time to test mine, and as yours, I get absolutely nothing. It is completely dead, and I am wondering if a smd fuse might have blown on the power supply board.
28 January 2025 at 19:59 #63171Jonathan McCall
BRONZE MemberHi Jacob – haven’t revisited I’m afraid, I was away at the weekend and had a ton of things on since. Did you try the green button ?
I’m afraid I wouldn’t know where to start, looking at the individual smd’s, even with a circuit diagram I’m a bit lost when it comes to testing the various components.
Would obviously be very keen to see if you get any joy.
Cheers
Jonny
28 January 2025 at 20:03 #63172Jacob Terp Christensen
BRONZE MemberNo, I haven’t tried the green button, and I don’t know what it is for. I’m not that interested in testing with live 230v on exposed capacitors, but it might be necessary to see where it goes wrong.
14 February 2025 at 17:20 #63785Jonathan McCall
BRONZE MemberAny joy Jacob ? Funnily enough there’s a post re and S8 not powering up. Looks like the capacitors could be an issue.
Cheers
Jonny
14 February 2025 at 17:29 #63787Jacob Terp Christensen
BRONZE MemberSadly not, I haven’t looked into it yet. Can you link the post? Would be interesting to see if it is the same problem.
14 February 2025 at 17:45 #63788Jonathan McCall
BRONZE Member14 February 2025 at 17:52 #63789Jacob Terp Christensen
BRONZE MemberThanks, I’ll watch the thread to see if any new info is shared. Although I do not get any hiss or anything, it might be of value.
3 October 2025 at 18:32 #70104adyan
BRONZE MemberHello,
also try to repair a Beolab 14 Sub, sadly I´m not the fist who opened it…
after inspecting the mainboard I found that there is a component missing, maybe someone can point me in the right direction what is missing there. Also would be nice to have a picture from this section.
There is also a problem with the NTC, see here:
https://forum.beoworld.org/forums/topic/beolab-14-subwoofer-repair/
Thanks in advance, Regards
You must be logged in to view attached files. -
