Home › Forums › Product Discussion & Questions › BeoLab › Beolab 1 problem
- This topic has 5 replies, 3 voices, and was last updated 2 years, 9 months ago by
BandOSteve.
24 April 2023 at 04:17 #46024
BandOSteve
BRONZE MemberHi all,
I have one of my Lab 1s going in to protection mode. Red light turns Green for a second then back to red.
I have disconnected the tweeter but no change.
Guess it’s an amp issue, any ideas anyone or is there anyone who will repair it ?
Thanks Steve.
25 April 2023 at 06:52 #46025Valve1
GOLD MemberWhere are you based ?
25 April 2023 at 09:37 #46026BandOSteve
BRONZE MemberHi, Poole Dorset <!–more–>
25 April 2023 at 09:47 #46027 BeobuddyGOLD MemberDisconnecting the tweeter doesn’t help. A ceased tweeter is the same as disconnecting it. Measure the impedance of the both mid and tweeter. When these show an impedance of several ohms less than 10 ohm, then the amplifier is faulty.
In case of a faulty amplifer, I can fix these in combination with maintenance to prevent other often strange symptoms.Located in The Netherlands.
25 April 2023 at 10:16 #46028BandOSteve
BRONZE MemberThanks, l will check impedance
My location is UK.
25 April 2023 at 13:38 #46029BandOSteve
BRONZE MemberImpedance values
Tweeter 6.8
Mid 7.4
