Home › Forums › Product Discussion & Questions › BeoGram › Beogram stylus pressures advice please
- This topic has 5 replies, 3 voices, and was last updated 1 year, 2 months ago by
Florent Castro.
6 December 2024 at 13:55 #61381
RIB2906
BRONZE MemberCan anyone help me with recommended stylus pressures please for SP10, SP12 and SP14 please? I see both 1.2 and 2g (?) for SP10 and 2g for SP14 in B&O documentation but no recommendation for SP12 elliptical.
6 December 2024 at 16:40 #61384mcevedy@mac.com
GOLD MemberI normally use 1.2g for an SP12 – it is the elliptical version of the SP10 – the SP14 is higher compliance. However I usually also tune a bit by ear as cartridges do seem to differ with age and condition – start at 1.2 g would be my suggestion and work up .1 g at a time!
7 December 2024 at 18:03 #61418RIB2906
BRONZE MemberThank you for your assistance Peter. My main concern was not to cause any damage to my records but I have experimented today and found that The SP12 I want to use seems to have a sweet spot around 1.4g so I’ll go with that. I couldn’t be sure whether I was being overly fussy here!
16 December 2024 at 20:21 #61677mcevedy@mac.com
GOLD MemberNo – the figure suggested is always just an indicator and tuning by ear is the best way as you have done. B&O cartridges all have low tracking weights and are extremely unlikely to damage the record – you do need to keep the stylus clean though.
7 January 2025 at 12:17 #62381Florent Castro
BRONZE Member(deleted as quoted wrong post)
7 January 2025 at 12:24 #62382Florent Castro
BRONZE MemberI normally use 1.2g for an SP12 – it is the elliptical version of the SP10 – the SP14 is higher compliance. However I usually also tune a bit by ear as cartridges do seem to differ with age and condition – start at 1.2 g would be my suggestion and work up .1 g at a time!
That is great advice. I had an old stylus which I thought was defective (lots of crackling noise on one channel) – I adjusted the tracking pressure and it turns out it works fine! Thank you Peter.
