Home Forums Product Discussion & Questions BeoCenter Beogram rx2 to beocenter 8500
  • #64849
    Antonio Tiago Terrivel
    Hi, need help to connect a beogram rx2 to a beocenter 8500, what connector should I use? Thanks
    #64924
    CharlieWednesday
    GOLD Member
    My Beogram RX2 is fitted with standard RCA plugs rather than the usual B&O DIN plugs, and my understanding is that this is normal for the RX2 and TX2, as they were intended for the wider market (in fact, my own RX2 is connected to a modern, non-B&O amplifier via standard RCA connection).
    You just need an RCA (female) to DIN adapter such as this one (but I’m sure you could find something better quality if you shopped around), and use that to connect it to the phono input of your 8500.
    My B&O Icons: No description available No description available No description available No description available No description available No description available No description available
