Home › Forums › Product Discussion & Questions › BeoCenter › Beogram rx2 to beocenter 8500
- This topic has 1 reply, 2 voices, and was last updated 11 months, 4 weeks ago by
CharlieWednesday.
31 March 2025 at 21:18 #64849
Antonio Tiago Terrivel
BRONZE MemberHi, need help to connect a beogram rx2 to a beocenter 8500, what connector should I use? Thanks
3 April 2025 at 20:59 #64924 CharlieWednesdayGOLD MemberMy Beogram RX2 is fitted with standard RCA plugs rather than the usual B&O DIN plugs, and my understanding is that this is normal for the RX2 and TX2, as they were intended for the wider market (in fact, my own RX2 is connected to a modern, non-B&O amplifier via standard RCA connection).
You just need an RCA (female) to DIN adapter such as this one (but I’m sure you could find something better quality if you shopped around), and use that to connect it to the phono input of your 8500.
