Home › Forums › Product Discussion & Questions › BeoGram › Beogram CD4500 lid
- This topic has 2 replies, 2 voices, and was last updated 3 months, 3 weeks ago by
orava.
6 December 2025 at 14:23 #71780
orava
BRONZE MemberHello
Were there any kind emergency hole or something for lid opening in case (this case) lid wont open?7 December 2025 at 05:20 #71789 Mark-sfBRONZE MemberAs far as I remember, there is no locking mechanism on the lid. The unit simply detects it going up or down to control the mechanism. If this is a unit that has been in storage or unused, it could have dried damping grease at the two hinges. I would first try using a blow dryer at low setting at the lids back hinge points to soften it. Then try lifting it by both front corners so the upwards pressure is equal.
8 December 2025 at 06:35 #71802orava
BRONZE MemberYes,you are right. At second tought I remember it also. I did access gearwheels after removing bottomplate.
