Home › Forums › Product Discussion & Questions › BeoGram › Beogram CD 7000 tray belt
- This topic has 6 replies, 3 voices, and was last updated 2 years, 9 months ago by
filip_kbh.
22 April 2023 at 09:55 #45949
BeitieGOLD MemberHello everyone. So after I had so much trouble with the Beocenter 9500 (I still have it and will fully restore that eventually), I found a Beomaster 7000 and Beogram CD 7000. I’ve always thought these were pretty cool systems, and some of the last of that style from B&O, so I picked it up.
The Beomaster works great, no issues or complaints. Condition is very good as well. Only a few light scratches and some very minor fading of the black paint on the top where the amplifier must have gotten warm enough to discolor it at some point.
The Beogram CD has been a little hit and miss for me so far. Condition wise, it looks excellent. Both of these items have been well taken care of. The first time I hooked it all up, it played a CD for me perfectly with no issues. Then when my Mom came over to listen to it, I put in a CD, and it would just skip like mad. The audio was un-listenable.
I’ve noticed that the CD tray would not fully close under it’s own power, so I do suspect a weak belt. However, I doubt that is the only issue. After that CD failed to play, I found that if I put my finger under the bottom of the CD tray and lift up on it very gently, it would play just fine. So maybe it needs some leveling adjustments?
Anyway, thanks all for sharing in this journey with me!
Favourite Product: Beocenter 9500
22 April 2023 at 22:04 #45950 BeitieGOLD MemberWhen I had it opened up, I also cleaned off the old lithium grease, and replaced with some new grease.
23 April 2023 at 19:38 #45951 chartzBRONZE MemberHi,
Have you considered rubber shock absorbers? Those are available here : https://www.beoparts-shop.com/product/disc-drive-suspension-rubber-repair-kit-for-beogram-cd5500-cd6500-cd7000.
21 May 2023 at 00:20 #45952 BeitieGOLD MemberThe new CD tray belt came in, and I replaced it. However, now it just will not play any CD’s that I toss in it.
I’m starting to think that the rubber shock absorbers that Chartz mentioned will be needed to complete this job. Luckily for me, another forum member was placing an order, and added a set of them so that I didn’t have to make yet another order.
Here’s a short video of how it’s operating now.
21 May 2023 at 09:05 #45953 chartzBRONZE MemberHave you recapped the servo PCB?
21 May 2023 at 19:22 #45954 BeitieGOLD MemberI have not. I do have at least one kit from Beoparts on hand, but I suck at soldering. The kit was going to be for my Beocenter 9500.
9 June 2023 at 22:59 #45955 filip_kbhBRONZE MemberC2103 is the one all important capacitor to change. Search on the forum and you will get a lot of hits. There could be others but I would start with this one. Since I changed it in my Beogram 7000 CD player, it plays absolutely everything. Before the change, it was very picky about which CDs it would play.
