Home Forums Product Discussion & Questions BeoGram Beogram CD 5500 won’t play
  • #50028
    paul-mck
    Anyone have any ideas on why a Beogram CD 5500 wont play?
    CD tray opens closes smoothly, “tracks” show on the front, but won’t play or show track numbers when play is pressed on unit or remote.
    Could it be a dirty laser lens, Capacitor, or drive belt?
    Thanks,
    P.
    Favourite Product: Beogram 5500
    #50029
    filip_kbh
    The main suspect is always C2103 for these types of decks. Once that has been changed, the troubleshooting can go into other capacitors.
    #50030
    Dillen
    What Filip said.
    And there is a convenient kit for the servo board for exactly this.
    Here.
    #50031
    paul-mck
    Thank you, I’ll order that kit and take it from there!
    P.
    #50032
    BellerophonBKK
    It is definitely worth trying something I picked up on one of the Bang and Olufsen forums (probably here) which worked for my white BeoGram 5500 before going down the capacitor route like I did (bought the one in the link) but luckily didn’t need to have. Just cleaning the CD lens, only took a few minutes then my white Beogram CD5500 sprung back into life.
    Favourite Product: Ouverture
