Home Forums Product Discussion & Questions BeoGram BEOGRAM CD 5500 STOPPED PLAYING CD
Viewing 10 posts - 1 through 10 (of 10 total)
  • #44723
    BEOGRAM5500
    Hello, i have cd5500 that now have stopped playing cd,s. spinning and laser is seaching and then stops. Weak light from laser. any ide,s. Recap all cap,s is one ide i have read about on net some time ago.
    Magnar.Norway.
    #44724
    Soren
    You would have to replace the blue Phillips capacitor C2108 and then your 5500  are playing again, that is a common problem on most  CD players.
    you can buy the kit here:
    Capacitor kit for CDm Disc Drive Servo Beogram CD Beocenter
    #44725
    filip_kbh
    It’s C2103. Indeed it’s the blue one to the left of the microprocessor on the above board. A very simple capacitor to change, as long as you get the right one 🙂
    #44726
    Motorman
    Its a axial 33µF 16V Capacitor. I just exchaned it on a Beogram CD7000:
    Old:
    P1040202
    New:
    P1040205
    I used a radial 33µF 25V one. It worked like a dream.
    #44727
    kronzilla
    Could be that the laser reach the end. Or laser current must be corrected ( don’t do if you are not familiar, you would kill the laser from overcurrent)
    #44728
    BEOGRAM5500
    Changed all  elktrolytte capasitors. Got a kit from Beoparts. Problem solved. AS NEW.
    #44729
    chartz
    Excellent, and well done. ☺️?
    #44730
    BellerophonBKK
    Any further details you can supply of the ‘simple’ change would be most appreciated for the non-electronic electorate amongst us, video, images would be fantastic
    #44731
    kronzilla
    Its a axial 33µF 16V Capacitor. I just exchaned it on a Beogram CD7000: Old: P1040202 New: P1040205 I used a radial 33µF 25V one. It worked like a dream.
    indeed. i read somewhere that you need to take a normal high esr elco, a low esr elco does not work there …
    #76727
    JK
    Can I check which make of capacitor you used for this fix, Panasonic, Vishay etc. Are you able to share a close up image of the actual capacitor you used?
    Thank you
