Home › Forums › Product Discussion & Questions › BeoGram › BEOGRAM CD 5500 STOPPED PLAYING CD
- This topic has 10 replies, 9 voices, and was last updated 1 week, 6 days ago by
TK.
15 March 2023 at 01:41 #44723
BEOGRAM5500
BRONZE MemberHello, i have cd5500 that now have stopped playing cd,s. spinning and laser is seaching and then stops. Weak light from laser. any ide,s. Recap all cap,s is one ide i have read about on net some time ago.
Magnar.Norway.
15 March 2023 at 06:31 #44724Soren
BRONZE MemberYou would have to replace the blue Phillips capacitor C2108 and then your 5500 are playing again, that is a common problem on most CD players.
you can buy the kit here:
16 March 2023 at 09:23 #44725 filip_kbhBRONZE MemberIt’s C2103. Indeed it’s the blue one to the left of the microprocessor on the above board. A very simple capacitor to change, as long as you get the right one 🙂
20 March 2023 at 19:59 #44726 MotormanBRONZE MemberIts a axial 33µF 16V Capacitor. I just exchaned it on a Beogram CD7000:
Old:
New:
I used a radial 33µF 25V one. It worked like a dream.
22 March 2023 at 14:54 #44727kronzilla
BRONZE MemberCould be that the laser reach the end. Or laser current must be corrected ( don’t do if you are not familiar, you would kill the laser from overcurrent)
22 March 2023 at 14:57 #44728BEOGRAM5500
BRONZE MemberChanged all elktrolytte capasitors. Got a kit from Beoparts. Problem solved. AS NEW.
23 March 2023 at 19:55 #44729 chartzBRONZE MemberExcellent, and well done. ☺️?
6 January 2024 at 21:39 #44730 BellerophonBKKBRONZE MemberAny further details you can supply of the ‘simple’ change would be most appreciated for the non-electronic electorate amongst us, video, images would be fantastic
Favourite Product: Ouverture
6 January 2024 at 22:15 #44731kronzilla
BRONZE Member11 March 2026 at 12:41 #76727JK
BRONZE MemberHi,
Can I check which make of capacitor you used for this fix, Panasonic, Vishay etc. Are you able to share a close up image of the actual capacitor you used?
Thank you
12 March 2026 at 03:00 #76953TK
BRONZE MemberI’ve used both Vishay 47uF 25v (MAL202136479E3) and 33uF 16v (MAL203035339E3), and both single-cap changes alone have restored the individual players to full operation. I can’t speak to whether these are the best brand/model choices, or whether a 47uF provides better tracking, but some have reported better results using a 47uF, saying that they are better equipped to read more modern discs. This has all been in the last year, so I have no longevity data.
I also don’t have a list of “while you’re at it” parts swaps, which would be a nice thing to have, if others have a list.
