Home › Forums › Product Discussion & Questions › BeoGram › Beogram CD 5500 right channel no sound
- This topic has 3 replies, 3 voices, and was last updated 2 years, 8 months ago by
Dillen.
10 June 2023 at 02:19 #47097
69er
BRONZE MemberHi B&O Fans,
a new small project on my table.
A Beogram CD 5500. After replacing the famous capacitor the CD runs now.
But unfortunately only on the left channel.
Cause i don´t have an oscilloscope – is there anything else, i should take a deeper look at?
I checked the solderings, but nothing obvious.
Best regards
69er
10 June 2023 at 14:42 #47098quattttro
BRONZE MemberI would check the relay first. Perhaps the right channel isn’t making adequate contact.
10 June 2023 at 17:10 #4709969er
BRONZE MemberHi quatttro,
where is the relay in a Beogram cd?
best regards
69er
10 June 2023 at 17:50 #47100Dillen
ModeratorCheck the filter capacitors and their respective resistors for the opamps in the analogue output stages.
