Home › Forums › Product Discussion & Questions › BeoGram › Beogram 8002 stops short
- This topic has 18 replies, 5 voices, and was last updated 3 years, 11 months ago by
beogram8002.
23 July 2022 at 17:05 #39516
Die_Bogener
BRONZE Memberdeleted
3 October 2022 at 01:32 #39504antlestxp
BRONZE MemberI have made some progress. This table didn’t turn on at all when I got it. I replaced all the caps and clean al the mechanicals to get to this point. It spins and locks on speed. I tested with a rpm tool. The carriage moves pretty freely in both directs. The part I’m stuck at is the arm stops short. It makes it to the same spot every time I press play and will just sit there spinning. It won’t respond to stop from this state. It will only respond to stop if play was never started. I did replace the led on the encoder and get pulses from the diode readers. I’m not sure what else to check.
3 October 2022 at 11:15 #39505Die_Bogener
BRONZE MemberYou start a Beogram to play without a record?
Nice, you will destroy the MMC if it continues.
That’s a safety feature.
3 October 2022 at 11:28 #39506 chartzBRONZE MemberHi,
This should be in the Workbench, where it’s really at as regards repairs.
Check your connections, and the bulbs, especially the one in the control panel, and if good, check adjustment as per service manual (5-3).
3 October 2022 at 18:51 #39507antlestxp
BRONZE MemberYou start a Beogram to play without a record? Nice, you will destroy the MMC if it continues. That’s a safety feature.
As you can see there is no cart attached. If a 45 is placed on the platter it does the same as well as a 12. It is clearly stopping short of the record detection process.
3 October 2022 at 18:54 #39508antlestxp
BRONZE MemberEverything in the control panel has been replaced and adjusted to spec. New bulb and photo sensors went in. It seems like an issue with the rotary encoder. The arm moves for a couple seconds before it stop. I’m going to check the connections between the encoder and cpu again when I have free time.
3 October 2022 at 20:50 #39509 chartzBRONZE MemberI remember I had to replace the IR diode in one of my decks. An easy task, if it comes to that!
3 October 2022 at 20:53 #39510sonavor
BRONZE MemberHave you performed the service manual adjustment for the forward and reverse scanning control buttons?
Both should measure around 620 mV at their steady-state (not pressed) position.
If those are adjusted correctly then perhaps you do have a problem with one of the position sensors.
Those can be replaced if necessary. I believe Martin has a replacement part at the Beoparts store.The source of the problem could still be elsewhere though.
To see what is going on for sure you would need to attach some probe wires to measure what the various sensors are actually doing.-sonavor
3 October 2022 at 21:06 #39511sonavor
BRONZE MemberSorry, I didn’t read the previous threads closely.
It sounds like you have set the steady-state levels on the scanning buttons where the LDRs measure 620 mV.I would connect an oscilloscope to the sensor signals and see if any are showing any signs of problems.
Here are the sensor measurements I captured on a Beogram 8002 a little more than a year ago. The oscilloscope measurements are towards the end of the post. There are also photos of where the test probe wires are soldered to.
-sonavor
4 October 2022 at 00:05 #39512antlestxp
BRONZE MemberI have replaced the emitter diode on the encoder. I can’t find the correct part for the 2 receivers.
4 October 2022 at 00:10 #39513antlestxp
BRONZE MemberSorry, I didn’t read the previous threads closely. It sounds like you have set the steady-state levels on the scanning buttons where the LDRs measure 620 mV. I would connect an oscilloscope to the sensor signals and see if any are showing any signs of problems. Here are the sensor measurements I captured on a Beogram 8002 a little more than a year ago. The oscilloscope measurements are towards the end of the post. There are also photos of where the test probe wires are soldered to. -sonavor
Thanks for pointing me in the right direction. Looks like you probe at r11 and r8 for the 2 receiver diodes. Do you know what part number the receiver diodes are if they are the problem.
4 October 2022 at 02:40 #39514sonavor
BRONZE MemberIf you used something like an OP240 or OP245 IR Emitter then their corresponding phototransistors are OP550 or OP 560 for the OP240 and OP555 or OP565 for the OP245.
The IR Emitters have been hard to get for a while but fortunately you already have that component.
Before changing any of these components I would measure the existing signals and make sure the part is where the fault is.
-sonavor
4 October 2022 at 04:08 #39515antlestxp
BRONZE MemberVery helpful. Your posts got me through a 4002 restoration! I used a camera to determine the emitter was faulty.
4 October 2022 at 17:14 #39517sonavor
BRONZE MemberGreat. You meant to write that you got through your BG8002 restoration, right?
Congratulations and good work.
-sonavor
5 October 2022 at 03:57 #39518antlestxp
BRONZE MemberNo I’m still working on this one. I meant I got a 4002 running from your blog a while ago.
5 October 2022 at 14:03 #39519sonavor
BRONZE MemberOh, that’s fantastic. We’re always glad to hear that it provided some help.
-sonavor
6 October 2022 at 05:01 #39520antlestxp
BRONZE MemberGot it up and running. Circled back to the basics. Checked my solder work. Pulled as much as the old solder my vacuum could. All new solder. Cleaned and checked all mechanicals. Then checked my work and calibration of the control panel. It was the control panel. My adjustment was close but not close enough. Had the relocate the new receivers into a better position then readjust with the screws. Soldered a connector to the panel I could leave measuring equipment to made quick work of it. Now I just need to finish up the rest of the adjustments to the tone arm.
Thanks again. This is my 4th and probably final beo. RX2 TX2 4002 and now this 8002. Every table I have wanted over the years.
6 October 2022 at 05:29 #39521 chartzBRONZE MemberGood job. Little things, always ☺️
14 October 2022 at 16:42 #39522 beogram8002BRONZE Memberwell done, that is great news, another 8002 playing vinyl again 🙂
