Home › Forums › Product Discussion & Questions › BeoGram › Beogram 8002 not turning on
- This topic has 30 replies, 5 voices, and was last updated 4 months, 2 weeks ago by
Jordi Veytia Iglesias.
4 October 2025 at 12:49 #70119
YannChrisGOLD MemberHi,
The triangular belt and a lot of electronic parts can be found at Danish Sound Parts.
Beogram 8000 – Danish Sound Parts
Regards,
Yann.
4 October 2025 at 12:51 #70120 YannChrisGOLD MemberDuplicate post
4 October 2025 at 23:26 #70152 Mark-sfBRONZE MemberGreat progress! As to you hum issue, this is most likely the wrong DIN cable adaptor. Since the table has a DIN socket, unless you are connecting DIN->DIN you need a DIN-RCA that has an additional chassis ground wire designed for turntable outputs.
6 October 2025 at 18:32 #70176Jordi Veytia Iglesias
BRONZE MemberThanks YannChris for the link to the belt, I’ll be sure to purchase it. In the meantime I used a regular stationary rubber band and it works pretty well . Of course durability is an issue, but for testing the device it works well. I’ll be sure to replace it soon with the triangular one.
And thanks Mark for the suggestions about the DIN-RCA cable. I currently have a generic one just for testing. But I’ll be sure to get the correct one and retest it.
I’ll keep you posted
🙂10 November 2025 at 23:31 #71050Jordi Veytia Iglesias
BRONZE MemberHello, how are you? I’m back 🙂
I have new updates. I got a grounded Din to RCA cable in order to connect the 8002 to the amp hoping grounding was the cause of the hissing noise. Sadly, that’s not the case. Even with the grounded cable the noise persists. I tested it with different amps to rule out a faulty connection on the amp side, but got the same results.
The hissing sound only appears when I press Play or Turn, if I press Stop the hissing sound stops. The hissing noise only appears to be present at the same time the platter motor is engaged.
I have also cleaned the connections with Deoxit and ensured the mechanism is floating correctly above the chasis.
If I put a second on it sounds fine but the hissing noise never disappears which makes listening to music not possible.
Does anyone know what could be causing this noise?
Thank youI’m attaching a video to demo the noise.
10 November 2025 at 23:34 #71051Jordi Veytia Iglesias
BRONZE MemberHere’s the video with the noise.
You must be logged in to view attached files.11 November 2025 at 02:08 #71055 Mark-sfBRONZE MemberI’m sorry but there was to much traffic noise in your video to zero in the noise you are referring to. What component are you connecting it to and specifically what cable are you using? If you are not using a DIN to DIN cable are you connecting the phono ground wire?
11 November 2025 at 19:19 #71087Jordi Veytia Iglesias
BRONZE MemberSorry for the poor audio from the previous video. I’m uploading a new one.
And yes, the ground wire is connected too.Attachments:
You must be logged in to view attached files.11 November 2025 at 19:20 #71090Jordi Veytia Iglesias
BRONZE MemberHere’s the new video
You must be logged in to view attached files.11 November 2025 at 20:35 #71095 Mark-sfBRONZE MemberSince the turntable is supposed to be muted at that point, this is a grounding problem. First, I would move the arm over and cue it down before the edge of the record to see if the sound changes when it unmutes. I will bet it does. If so, then your 3rd party DIN cable does not have the ground wire connected properly. It needs to connect only to the DIN connector sleeve. If it is connected properly, then the issue may be on the connector board in the turntable.
12 November 2025 at 22:59 #71122Jordi Veytia Iglesias
BRONZE MemberHello, thanks for the feedback Mark. I re-wired the cable to make sure the grounding pin was connected to the sleeve on the Din plug and that fixed the issue. The 8002 is now sounding great!
I’ll start work on the busted dust cover to finalize the complete restoration.
Thank you all for your support! -
