Home › Forums › Product Discussion & Questions › BeoGram › Beogram 8002
- This topic has 4 replies, 4 voices, and was last updated 2 years, 4 months ago by
AdamS.
14 November 2023 at 04:09 #50451
kokobeware
BRONZE MemberHi I have a Beogram 8002 with an MMC4 cartridge. I’m looking for a phone preamp. Is there a certain type I should be purchasing to work with my unit? On the Sound Smith site the MMC4 is listed as • Fixed Coil / Moving Iron
Any suggestions $500-1,000 ?
14 November 2023 at 06:36 #50452 Mark-sfBRONZE MemberYou simply need a Moving Magnet Phono Preamp even though your cartridge is a moving iron type. I can recommend the Schiit Mani as a great value. There are also ones from Parasound, Pro-Ject, and Rega to name other quality units.
14 November 2023 at 12:30 #50453Mark
BRONZE MemberI have a Beogram 8002 with a Soundsmith SMMC1 cartridge and the MMP3 phono preamp and it sounds absolutely wonderful. I’ve read that the Soundsmith preamps are designed for their cartridges. There are a lot of opinions regarding vinyl that it is nowhere as near as good as the digital version, but that is not my experience at all. I guess a lot of it would depend on the quality of the record, cartridge, and preamp. I could listen to vinyl all day and never tire of the sound, but it some work prepping the album for play.
I think the choice of phone preamp depends on how much enjoyment you want to get from your vinyl, and how revealing your system is to be able to hear small differences. As Mark-sf says, pretty much any moving magnet phono preamp should be able to do the job, and there are budget phono preamps that are very good. I’ve had several budget preamps (not the ones listed above) but I don’t remember saying “oh wow!” when I listened to albums with them. The Soundsmith MMP4 is about $800 US, that’s quite an investment, but if you are after the best sound, have a good system, and think you may someday upgrade to one of the other Soundsmith cartridges, that could be a serious contender.
Good luck in your quest!
16 November 2023 at 04:42 #50454kokobeware
BRONZE MemberThanks for the replies guys.
17 November 2023 at 13:59 #50455 AdamSBRONZE MemberIn my experience, the best phono stage for a Beogram 8002 is the one built into a Beomaster 8000!
