Home Forums Product Discussion & Questions BeoGram Beogram 7000 PLAY problem
Viewing 15 posts - 1 through 15 (of 15 total)
  • #63070
    filip_kbh
    I have a Beogram 7000 record player that has developed a strange problem. When I press PLAY, the arm travels to the start of the record, and the 33 RPM light is on and the platter spinning. However, it then stops the platter and turns off the 33 RPM light. You then have to press play again, and it will start playing. Any ideas why? Is it just a worn out belt or is there perhaps an electric problem?
    #63110
    Dillen
    Oxidated microswitch, perhaps.
    #63116
    filip_kbh
    Amazing. I cleaned S1 and S2 with a fibre brush pen, and now it works as it should again. Thanks, Martin!
    #63121
    filip_kbh
    I spoke too soon. It fixed the issue when pressing the top PLAY button, however, when pressing the front PLAY button, it sometimes only spins the record and moves the arm to the beginning of the record. It also doesn’t turn on the amplifier if it is in standby mode. I can live with it but would love to fix this issue too.
    #63124
    pepps
    Hi Filip, it may be worth popping the turntable carefully into service position and closely studying the solder joints from the front panel back to the power supply. Re-solder any dodgy-looking joints if there are any.
    Favourite Product: Beosystem 6500
    Mark-sf
    Do you have pins 6 and 7 in the phono cable DIN plug? Those can be missing as they screw in and are needed for datalink communications such as turning on your receiver.
    #63159
    filip_kbh
    Yes, I have all 7 pins.
    The switch under the front panel PLAY button was very corroded. I cleaned it but it is falling apart, and I can’t seem to position it correctly for it to work when I press the PLAY front. After fiddling with it for hours, I have decided to accept that it doesn’t work. Can I replace it with another type of tactile switch? It seems to be a rather cheaply made board where a piece of tape was holding the metal plate in place. Any suggestions?
    #63166
    filip_kbh
    Argh – I am getting tired. Now I only have sound in the right speaker.
    #63169
    Mark-sf
    Yes, I have all 7 pins. The switch under the front panel PLAY button was very corroded. I cleaned it but it is falling apart, and I can’t seem to position it correctly for it to work when I press the PLAY front. After fiddling with it for hours, I have decided to accept that it doesn’t work. Can I replace it with another type of tactile switch? It seems to be a rather cheaply made board where a piece of tape was holding the metal plate in place. Any suggestions?
    It is simply a piece of conductive spring metal that should be able to be cleaned if desoldered. You could switch it with for example the 45-speed one if its damaged. A pushbutton microswitch such as one of these should be able to be retrofitted with minor board modifications, though I have not personally tried it.
    #63176
    filip_kbh
    It was a DIN wire that had broken off. Does anyone have a diagram for wires? I have sound in right and left channel now but datalink doesn’t work, so I presume I have soldered the datalink wire (yellow) to the wrong pin.
    #63177
    Mark-sf
    This depends on your version. If it has the RIAA preamp, then it is pin 7. If not and you plug in into the Phono input of your receiver, it is pin 6.
    #63178
    filip_kbh
    The BG7000 has an RIAA preamp.
    #63304
    filip_kbh
    Indeed the problem was that I had soldered pin 6 instead of pin 7. Now it works. Time will tell when I revisit that front PLAY button issue. I think the board needs to be positioned very accurately for the pin to hit the conductive spring, so it may just be a matter of misalignment as the board works when I press it with a finger.
    #72809
    BeoMedia
    I also have a BeoGram 7000 but a different issue. When playing records the little display next to the toner arm has a flashing “33”. The record plays fine and feels like at correct speed but why the flashing as opposed to a constant “33” displayed?
    kind regards
    • This reply was modified 3 hours, 18 minutes ago by BeoMedia.
    #72812
    filip_kbh
    If the display is flashing, it means the record is repeated from one time to seven times. If this happens when you only press play once, it’s usually because of a corroded switch.
