Home › Forums › Product Discussion & Questions › BeoGram › BEOGRAM 7000 45” records
- This topic has 1 reply, 2 voices, and was last updated 2 years ago by
Dillen.
23 January 2024 at 06:28 #52375
Jojoe
BRONZE MemberHello,
My BEOGRAM 7000 doesn’t automatically pick up the small (45”) circuit boards, but tries to play a 33mm record and the pickup lands on the metal
Otherwise the record player works perfectly
(I can start the 45” manually!)
How does the detection of the circuit board size work and does anyone have an idea where the error could be?
JoJoe
23 January 2024 at 22:33 #52376Dillen
ModeratorCenter puck seized in the down position?
Using a record weight? – Don’t!
Using an antistatic mat? – Dont!
If the latter throw the mat away or sell it to somebody who cares less about correct tracking angle and risk of stylus damage. It has no use on any Beogram anyways.Martin
