Home › Forums › Product Discussion & Questions › BeoGram › Beogram 6006 – Arm not going back to parking position
- This topic has 6 replies, 2 voices, and was last updated 2 years, 4 months ago by
YannChris.
4 November 2023 at 12:15 #50192
YannChrisGOLD MemberHello,
Sometimes (and more often since a few time), the arm of my Beogram 6006 does not return to parking position at the end of the disc.
It happens when the end-groove is very close to the center, so the reading arm is far on the label.
When pressing stop, I hear the motor spinning but the arm does not move. Same with the fast return key.
It looks as the moving cart has gone out of the guiding spindle.
Today, I solved the problem by moving this spindle by hand, but it is not satisfactory.
A played a “shorter”LP with a larger end-groove palyed without problem.
Can I check something?
Thanks by advance,
Yann.
4 November 2023 at 12:27 #50193Dillen
ModeratorReplace the wedge-shaped belt for the carriage motor.
Also dirt and/or dry lubricants towards the leftmost end of the threaded spindle can cause
excess friction and make the belt slip.
Clean the threaded shaft and add a handful tiny drops of teflon oil.Martin
4 November 2023 at 12:34 #50194 YannChrisGOLD MemberThanks Martin,
I found the belt on Beoparts, but I absolutely don’t know where to find the teflon oil.
Is there a brand/name that you can recommend?
Kind regards,
Yann.
4 November 2023 at 14:49 #50195Dillen
ModeratorI bought something on Ebay years ago called “liquid bearing”.
4 November 2023 at 19:50 #50196 YannChrisGOLD MemberOk, Thanks.
15 November 2023 at 18:56 #50197 YannChrisGOLD MemberHi Martin,
The new belt is arrived and I sourced teflon bicycle oil for dry condition.
A question: How to remove safely the transport in order to clean the threaded spindle and what attention points should I take care of?
Kind regards,
Yann.
19 November 2023 at 10:22 #50198 YannChrisGOLD MemberUpdate:
Belt exchanged.
Threaded spindle cleaned withoud removing the arm. Not perfect but I did what I could.
Then lubrification with the above-mentioned lubricant.
The arm acts now as designed.
Let’s hope it will last.
I’d liked to have the BG recapped, but it’s out of my competencies.
Yann.
