Home › Forums › Product Discussion & Questions › BeoGram › Beogram 6006/8000/8002/TX creaking dustcover hinge
- This topic has 4 replies, 3 voices, and was last updated 7 months ago by
PeteV.
9 September 2025 at 17:33 #69508
PeteV
BRONZE MemberHello,
I’m restoring a Beogram TX, and I’m having an issue with the dustcover hinge – it creaks loudly when lifting/lowering it.
I’ve dismantled the hinge several times, tried adding some lubricant between the plastic guide and the plinth, but it doesn’t help.
I noticed in an article on Beolover’s site, that there should be a teflon strip between the plastic guide and the plinth main body, which presumably allows the guide to slide more smoothly; howeer this is absent on my Beogram. Does anyone know the size of the teflon strip and how it is attached to the plinth – presumably some type of glue? The service manual is of no help here
Thanks in advance
Pete
9 September 2025 at 19:46 #69514 YannChrisGOLD MemberHi Pete,
Look at this:
https://www.dksoundparts.com/product-category/beogram/beogram-tx/
Regards,
Yann.
10 September 2025 at 09:59 #69528PeteV
BRONZE MemberHi Yann,
Yes, I have seen that. However, as far as I can see this does not include the Teflon strip.
Regards
Pete
14 September 2025 at 07:25 #69642Dillen
ModeratorThe teflon sheet is apprx. 2 x 3 cm.
15 September 2025 at 07:51 #69679PeteV
BRONZE MemberThanks, Martin.
I’ve replaced the teflon, and problem is now solved.
