Home › Forums › Product Discussion & Questions › BeoGram › Beogram 6002 pause issue
- This topic has 1 reply, 2 voices, and was last updated 3 years, 7 months ago by
spassmaker.
24 August 2022 at 08:45 #37218
kris159357
BRONZE MemberHi
im hoping someone may have some ideas as I’m located in Australia and having difficulty finding someone to repair this.
when I play a record sometimes it will play through other times it will automatically lift the tone arm mid play and won’t go back down unless you hold the play button
thanks for your help
kris
25 August 2022 at 10:25 #37219 spassmakerBRONZE MemberHi Kris
If not already done, I would consequently renew all caps on the PCB’s.
The caps are comming to age sooner or later and loose their capacity, so there is a good chance to bring your turntable back to life.
Recommended is also to check and reflow the solderjoints of the connection plugs and sockets.
Ask member Martin at http://www.beoparts-shop.com for a capacitator kit and new belts for the platter and the tangential drive.
Regards
Christian
