Home › Forums › Product Discussion & Questions › BeoGram › Beogram 6000 output.
- This topic has 1 reply, 1 voice, and was last updated 2 years, 10 months ago by
Justshoemark.
29 April 2023 at 10:04 #46119
Justshoemark
BRONZE MemberHi all I have a beogram 6000.
It’s one with a built in riaa but it seems the output is low I can nearly max out the volume control.
I am using it with a none bang and Olufsen system. And using it in to a Densen pre amp.
When I have looked up the beogram 6000 it says the output is 200mv is this correct?
Many thanks
1 May 2023 at 22:41 #46120Justshoemark
BRONZE MemberCould there be a fault in the cd4 unit the inbuilt phono stage.
Many thanks
