Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5500 to Kanto YU5 speaker set up help
- This topic has 21 replies, 4 voices, and was last updated 6 months, 3 weeks ago by
Nebojsa Jankovic.
16 September 2025 at 18:44 #69707
Emma Kitley
BRONZE MemberCould anyone please help me – trying to connect a B&O Beogram 5500 record player to Kanto speakers. Have attached a photo of the set up; 7 pin din to rca cable > pre-amp > speaker. Faint sound coming from record player itself so that seems to be working, but no sound out of speaker! Any advice would be greatly appreciated!
You must be logged in to view attached files.16 September 2025 at 19:24 #69709Nebojsa Jankovic
BRONZE MemberHello Emma, you have an active speaker, so you need additional Line Level Booster connected between your preamp and your speaker, see attached photo for a proven one, from Nobsound (Douk Audio).
Kind regards, Nebojsa
You must be logged in to view attached files.Location: Eindhoven, NL
Favourite Product: Beogram 4002/04, Beocenter 7007, Beosound 6000/02
16 September 2025 at 19:40 #69711Emma Kitley
BRONZE MemberThank you so much!
17 September 2025 at 06:42 #69715Nebojsa Jankovic
BRONZE MemberHi Emma, have you tried connecting your turntable directly to the speakers?
17 September 2025 at 08:37 #69716Emma Kitley
BRONZE MemberI did try this initially, but no luck, and after some research it appeared that the 5500 doesn’t have a pre-amp built in so others had bought an external one…
17 September 2025 at 08:47 #69717Emma Kitley
BRONZE MemberI have read that I might need a specific Beogram DIN to phono cable? But not sure why that would be…
17 September 2025 at 18:16 #69723 YannChrisGOLD MemberWrong post, sorry.
Regards,
Yann.
19 September 2025 at 19:09 #69776Emma Kitley
BRONZE MemberI bought a line level booster but unfortunately this hasn’t worked, still just receiving static…
19 September 2025 at 21:00 #69780 YannChrisGOLD MemberDear Emma,
Your pre-amp seems to be the same as one sold by Sounds Heavenly.
If yes, you might ask Steve’s help to solve your problem.
A few questions to help your investigations:
- I noticed on your picture that the pre-amp’s LED is orange, isn’t it a warning (check the user guide)?
- Do your speaker work with another source plugged in the RCA inputs?
- Did you select the RCA input with the input selector of your speaker (it does not seem to automatic)?
- Looking at the YU5 user guide, this speaker has optical inputs that I don’t see on your picture. Are you sure yours is a YU5?
- Is the turntable’s cartridge correctly plugged on the reading arm?
If you have another product with RCA inputs, you could connect the pre-amp out to this product.
Kind regards,
Yann.
19 September 2025 at 21:15 #69782 Mark-sfBRONZE MemberYou need a Phono DIN adapter cable to go into your preamp such as this one: https://www.av-connection.com/?PNo=AV-DINPHONO&gad_source=1. The one you’re using is likely connected to the wrong pins and also needs the ground wire.
19 September 2025 at 21:30 #69783Nebojsa Jankovic
BRONZE MemberThe speaker in your photo seems to be just Kanto YU, basic model, so does not have input type selector…
19 September 2025 at 21:37 #69784Nebojsa Jankovic
BRONZE MemberSteve sells the SubZero PPA-2 preamp with input gain and monitor level controls.
20 September 2025 at 15:09 #69796Nebojsa Jankovic
BRONZE MemberHi Emma, I sympathize with you at this moment, as I imagine you are overwhelmed with responses and suggestions! Nevertheless, your first thing to eliminate is the DIN5/7-to-RCA cable, as where everything starts (or ends) is literally in the pinout compatibility from the BG5500 DIN5/7 plug to the corresponding female DIN5/7 plug on a DIN-to-RCA cable. So, either Sounds Heavenly (Beogram to non-B&O device phono preamp, amplifier, receiver, with internal ground link) or AV Connection (AV-advance B&O turntable adapter) cable should work, as both are specificaly wired to work with any Beogram turntable. Do note, again, that Sounds Heavenly cable does not come with a separate ground wire next to the two RCA’s, so is pre-wired to make it compatible with any non-B&O device, because not every preamp or amp/receiver comes with a ground terminal to connect to…
20 September 2025 at 19:55 #69797Nebojsa Jankovic
BRONZE MemberHello Emma, I need to clarify once again! Sorry if I was confusing you. As I had already said on Sep 17th, your best bet is to get the correct DIN-to-RCA cable, then go through your RIAA preamp to your speakers, as they do have an amplifier built-in. This should simply work…
22 September 2025 at 13:46 #69836Emma Kitley
BRONZE MemberHi Yann, Mark and Nebojsa,
Thank you so much for your continued help an invaluable – I am so appreciative! Apologies for my slow response, I am juggling trying to get this record player to work, while caring for my newborn baby!
In the first instance I have bought a new DIN to RCA cable from Sounds Heavenly as it does seem that B&O pins are wired differently – fingers crossed this works… will keep you posted!
Thanks so much again, Emma
22 September 2025 at 15:02 #69840Nebojsa Jankovic
BRONZE Member😀 Make it work, so your baby will take it over and enjoy it
22 September 2025 at 15:16 #69841 YannChrisGOLD MemberYou are welcome, Emma.
23 September 2025 at 03:15 #69854 Mark-sfBRONZE MemberIn the first instance I have bought a new DIN to RCA cable from Sounds Heavenly as it does seem that B&O pins are wired differently – fingers crossed this works… will keep you posted!
Emma, if you get sound but have a hum using the Sounds Heavenly cable, return it and get one that has a separate ground wire that you connect to the thumb screw on your phono preamp. I included an example in my previous reply.
24 September 2025 at 18:02 #69885Emma Kitley
BRONZE MemberSo happy to report that with the new DIN to RCA cable from Sound Heavenly, the record player works! Luckily there doesn’t appear to be any extra hum, (thank you Mark for the suggestion though)
Thank you so much to everyone for all your help – I never ever would’ve gotten it working if it weren’t for you all!
While playing records today, we got some smiles from our son ❤️
24 September 2025 at 19:24 #69889 YannChrisGOLD MemberGreat! 👍
Happy for you, Emma.
Kind regards,
Yann.
