Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5500 arm movement
- This topic has 9 replies, 2 voices, and was last updated 2 years, 4 months ago by
LexBarker.
20 November 2023 at 09:03 #50622
LexBarker
BRONZE MemberHi Forum,
this is my first post here. I live in Germany, 55 yers old and own several turntables(Sony Biotracer, Beogram).
I have a Beogram 5500 / 5941 / SW1.2(if this is important for this case).
First:
I have cleaned and lubricated the guide bars after the tonearm hanged once during play using teflon based grease.
It still hangs during play after some minutes and I try to figure out what is happening here. If then restarted, it runs through the record with no issue. From my personal opinion the tonearm is still heavy to move (manually) even after I lubricated both bars. I also replaced both belts using parts from beoparts. When the deck is opened all motors are running fine, but as said the tonearm sometimes gets stuck. What Do I have to check first?
Second:
This is a strange one:
The tonearm using the < and > keys moves slowly (could be normal for Beograms) to the left and to the right. It sometimes hangs during movement when it moves to the left only AND keep pressing < right from the beginning it only moves until the middle of the record and it stops(motor for the tonearm also stops!) and only If I press then play and then < again the tonearm continue to move to left until the end of the record. Therefor I am not able to start with an inner track of the record when the tonearm is in its rest area .
Did I somehow confuse the mechanics(I moved the middle gear by mistake)? For me it looks like the tonearm is moving until to the position where smaller records starts and not further(As said only continues to move further when I press Play and then < again) .
Hope this makes sense,LexBarker
20 November 2023 at 09:29 #50623Dillen
ModeratorThe felt clutch could have lost friction.
Can you tell, if it’s slipping?Martin
20 November 2023 at 10:05 #50624LexBarker
BRONZE MemberGood hint!
Let me check later today.
If so, what can I do?LexBarker
20 November 2023 at 11:23 #50625Dillen
ModeratorTake apart and clean. In most cases that’ll do it.
Else, the friction can be increased if you rough up the plastic surfaces a bit.Martin
20 November 2023 at 13:44 #50626LexBarker
BRONZE MemberHi,
how can I take it apart without removing the gear on top of it?
I turned it a little bit and now it works, but as I already opened it for servicing a hint how to take it apart would be great. And with what do I clean it?
Thanks,
LexBarker
20 November 2023 at 14:42 #50627LexBarker
BRONZE MemberHey Martin,
once I all put together (Platter, Spinwheel,…) I can confirm the felt clutch is slipping when using the key < to move the arm..
Okay, now the part where I need your help (see previous post)
Best,
LexBarker
20 November 2023 at 16:40 #50628Dillen
ModeratorYes, the cam wheel on top needs to come off.
You can take it off and, while keeping the strings tight, take out the worm gear assy with
the felt clutch, and put back the cam while working with the clutch assy.Martin
20 November 2023 at 16:46 #50629LexBarker
BRONZE MemberHi,
already disassembled.I have the worm gear assy removed.
How can I access the felt clutch in the assy and how to clean it?
Best,
LexBarker
20 November 2023 at 17:06 #50630Dillen
ModeratorI normally work within the small space allowed by the spring action.
20 November 2023 at 17:10 #50631LexBarker
BRONZE MemberAnd what do you use to clean it?
Bathing it in something?
