Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5005 User Manual?
- This topic has 6 replies, 3 voices, and was last updated 3 years, 11 months ago by
Clarbasspo.
14 April 2022 at 11:36 #34207
sushistar
BRONZE MemberI have another TT and for aesthetics I recently acquired a 5005 with an MMC3 and was an idiot not knowing that the RIAA was not in it when adding it to my 2500 system (stupidity tax). Is there a better way to connect it rather than the cumbersome PrePreamp route and gender changing din/beolink cables to RCA and back? I already have a PrePreamp for my other TT setup.
Part 2 is what about getting a user manual? Where? how much should I pay?
TIA
Peter
15 April 2022 at 06:03 #34208 Mark-sfBRONZE MemberMy recommendation would be to add an RIAA board inside such as https://www.ebay.com/itm/185373986428?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=i_P7_Iv4Tsu&sssrc=2349624&ssuid=WrB3U2kWQBO&var=&widget_ver=artemis&media=COPY. This is just an example of one that can run off of the +12v single supply. I’m sure there are higher quality ones if you scout around. You can find the user and service manuals on Beocentral.com.
6 May 2022 at 09:49 #34209Clarbasspo
BRONZE MemberHi Peter,
About the beogram 5500 manual you can download it here : https://www.vinylengine.com/library/bang-and-olufsen/beogram-5500.shtml
Otherwise about your RIAA problem for my part I’m using a Inakustik pre-amp that fit pretty well with my beogram 3000.
Pierre
6 May 2022 at 10:18 #34210Clarbasspo
BRONZE MemberSorry, I confused between the 5005 and 5500…
There is the good link for the 5005 :
https://www.vinylengine.com/library/bang-and-olufsen/beogram-5005.shtml
Pierre 😉
6 May 2022 at 12:17 #34211sushistar
BRONZE MemberPierre,
Thank you for the links, the site looks great to use however, they ask for a login/new account for the download. Unfortunately, they have turned off the “new” registration capability so I cannot access the files. Great sleuthing and resource! Thanks again!
P
6 May 2022 at 12:19 #34212sushistar
BRONZE MemberThank you again, I found another that had the DIN style connectors and may acquire it so that I could wire it in between the connections from the back of the receiver. I’ll look at it a little later as sailing season is upon us!
6 May 2022 at 13:50 #34213Clarbasspo
BRONZE MemberIf wish I can load it for you and send it by email
Pierre
