Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5005 end of play issue
- This topic has 5 replies, 2 voices, and was last updated 3 years, 12 months ago by
Jerryege.
4 April 2022 at 08:58 #33870
Jerryege
BRONZE MemberI have a beogram 5005 which starts, drops, and tracks beautifully but when it gets to the end of the record it doesn’t lift and return straight away. I thats a number of goes to track the last bit with the tone arm jumping back before eventually lifting and returning to park correctly.
Any ideas?
4 April 2022 at 21:05 #33871Jerryege
BRONZE MemberVideo here.
5 April 2022 at 01:26 #33872 mexkingBRONZE MemberCheck the needle pressure if that doesnt help check the end of play adjustment according to repair manual
5 April 2022 at 05:17 #33873Jerryege
BRONZE MemberI have slightly over weighted the needle pressure to help but is making no difference.
I have been through the manual and cannot see an end of play adjustment, only a set down adjustment. Could you show me this section please?
5 April 2022 at 16:25 #33874 mexkingBRONZE MemberI have slightly over weighted the needle pressure to help but is making no difference. I have been through the manual and cannot see an end of play adjustment, only a set down adjustment. Could you show me this section please?
You are right, no end of play adjustment. Check that Switch S3 and Relay R2 is working, and all the mechanic parts for PU arm up/down are clean and lubricated and moving freely
22 April 2022 at 11:40 #33875Jerryege
BRONZE MemberIts like the tracking is sluggish.
I’m going to replace the LDP light dependent photoresistor to see if that helps.
Does anyone know the rating for this?
