Home › Forums › Product Discussion & Questions › BeoGram › Beogram 5005 an Beosystem 3
- This topic has 3 replies, 2 voices, and was last updated 1 year, 11 months ago by
beos6.
27 March 2024 at 07:52 #53883
beos6
BRONZE MemberDear people, the Beogram 5005 does not have a built-in amplifier.
Is it possible to connect it directly to the Beosystem 3 or do I still need an amplifier in between?If so, what would be suitable?
I would like to have it in my setup 🙂
thanks in advance for the answers
31 March 2024 at 18:14 #53884beos6
BRONZE MemberHat niemand eine Idee?
ginge auch ein älterer Beomaster 3000?
31 March 2024 at 20:46 #53885 matadorModeratorSorry to answer in English.
Yes, you need an RIAA box to connect a BG5005 to… Anything that is not a Beomaster or a phono amp.
Which one is up to you: from cheap ones from the Bay to expensive dedicated ones, they are plenty of choices: it all depends of your budget, ears, tastes and needs…
Hope this helps.
12 April 2024 at 19:43 #53886beos6
BRONZE MemberThank you matador 🙂
can you recomend a special one?
