Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4500
- This topic has 7 replies, 2 voices, and was last updated 5 months, 1 week ago by
Paul Cheacker.
25 October 2025 at 22:29 #70682
Paul Cheacker
BRONZE MemberMy Beogram 4500 hinge has come out if its location, i noticed some plastic broke off where it was attached… is there a wat of fixing the hinge back to the top plate as it will not go back in place.
25 October 2025 at 22:48 #70683Paul Cheacker
BRONZE MemberBeogram 4500
26 October 2025 at 02:49 #70687 Mark-sfBRONZE MemberDid the plastic break off from the lid or the rear where the hinge attaches? Can neither screw attach? Best would be to upload a picture
26 October 2025 at 09:45 #70704Paul Cheacker
BRONZE Member26 October 2025 at 09:55 #70706Paul Cheacker
BRONZE MemberIt broke of the top plate where it fits onto the beogram 4500
You must be logged in to view attached files.26 October 2025 at 09:58 #70708Paul Cheacker
BRONZE MemberLooks to me like the area the screw fir the hinge screws into the plastic around it broke someone tried a repair that worked for a while, however to me not a good repair. Im trying to figure out how i can fix it better and what to use to do so.
27 October 2025 at 00:06 #70726 Mark-sfBRONZE MemberYour cropped closeup had me confused as to where the failure was. It is actually the hinge base not the hinge which has lost its screw. My recommendation would be to epoxy a nut (or if not wide enough add a washer) to the underside from which a screw from the top can thread.
27 October 2025 at 17:26 #70734Paul Cheacker
BRONZE MemberThanks i got sine epoxy and it worked perfecty
