Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4500 platter motor keeps spinning
- This topic has 3 replies, 2 voices, and was last updated 1 year, 9 months ago by
Jonathan McCall.
1 December 2024 at 11:40 #61256
Jonathan McCall
BRONZE MemberHaving re-capped the main PCB and RIAA boards everything is back together. I do however have one issue which needs the collective wisdom of the wise old elves on the forum.
My main platter motor keeps spinning, whether the unit is switched on or off, or the Phono selected on the main system or not.
Bit of a head scratcher, but I’m unable to test everything else until this is sorted.
The case is flipped open, no cartridge fitted and solenoids seems to work fine.
Help !
Cheers
Jonny
1 December 2024 at 17:30 #61262Dillen
ModeratorTR4 or TR5 shorted.
Replace both (BC337).Martin
1 December 2024 at 17:59 #61263Jonathan McCall
BRONZE MemberSmashing – many thanks Martin. Are all transistors pretty much the same, or are some better quality than others ?
7 December 2024 at 19:44 #61420Jonathan McCall
BRONZE MemberReplaced TR4 & TR5 today and now have the platter starting and stopping as it should.
Im now into an issue with the tonearm height and getting it balanced, so will post separately.
Thanks for the heads up on replacing the transistors – really helpful.
