Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002 – or 4000 wood replacement
- This topic has 1 reply, 2 voices, and was last updated 3 years, 4 months ago by
spassmaker.
31 October 2022 at 11:56 #40395
beostuff
BRONZE Memberhas anyone replaced the wood surround on a 4002? If no any tips?
1 November 2022 at 13:56 #40396 spassmakerBRONZE Member- Hi
If the wooden surround is still in place on the metal frame you could easyly put a new wood veneer trim on it like this:
https://www.ebay.de/itm/264966647721 (google search)
I’m not the seller or something like this.
This veneer has a paper laminatet backside, is easy to cut with a sharp knife.
As glue you could use a kontact cement like Pat..x.
Sanding the edges with 180 -320 grid.
Spray with semi matte clear coat and enjoy the new look.
Regards
Christian
