Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002, clack, scratch sound
- This topic has 23 replies, 4 voices, and was last updated 2 years, 6 months ago by
Renfield.
18 September 2023 at 14:57 #48809
Renfield
BRONZE MemberHello everyone,
It must have been a lot of static on my BeoGram 4002z
When I added a anti static mat on the platter, the clack sound disappeared.
I remember to take it if when I play 45’s.???
Thanks very much for the advises.
Mats/ Renfield
18 September 2023 at 14:58 #48810Renfield
BRONZE MemberTake it of when I play 45’s ?
M/
18 September 2023 at 17:48 #48811Dillen
ModeratorSorry to spoil the fun, but anti-static mats are absolutely NO-GO on any Beogram.
First; Due to the thickness of the mat, the needle tracking angle will be wrong.
Second; Because the presence of a record is often determined by either optical
sensors or weight, many Beogram models will think there is a record on the
platter – even if it’s merely the mat, and they will gladly try to play it…
A needle lowered onto a rotating felt mat… Ouch, – bye needle.Third; One is never needed, if the deck is in good working order.
You could run a grounding wire from a bolt of the main bearing (note its position or you
will have to realign the bearing) to somewhere on the main metal chassis.Martin
19 September 2023 at 09:55 #48812Renfield
BRONZE MemberOops,
I will try to ground the turntable then.
Thanks!
Mats
