Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4002 bearing
- This topic has 12 replies, 5 voices, and was last updated 3 years, 10 months ago by
calman65.
1 June 2022 at 12:19 #35227
calman65
BRONZE MemberHello all, what are my options for replacing the spindle bearing on 4002 type 5513 . The platter seems to have to much side to side movement . The tt does play and I have recapped it .Thanks , James
1 June 2022 at 16:46 #35228 chartz
BRONZE MemberHi James, and welcome ?
This is absolutely normal for that bearing. It is a self-centering bearing with only one sintered ring at the top. It has a special thrust pad at the bottom.
1 June 2022 at 17:52 #35229calman65
BRONZE MemberOk thanks , I don’t see the thrust pad . The spindle is convex and inside the main bearing is concave , there should also be a thrust pad ?
2 June 2022 at 17:22 #35230 chartz
BRONZE MemberThere is always one.
2 June 2022 at 17:45 #35231calman65
BRONZE MemberDo you know what the pad looks like, got a picture? The way the spindle fits into the bottom of the bearing on my 4002 seems to center it.
3 June 2022 at 00:27 #35232calman65
BRONZE MemberI was wrong about the inside of the main bearing. I got a better look, and it is flat with a small deep hole in the center. This small hole might center the spindle. I have not found any mention of the thrust pad yet. The spindle needs something to center it, or it will rub on the single sintered ring. Maybe the little hole?
3 June 2022 at 10:53 #35233 Mark-sfBRONZE MemberI believe the confusion is due to the 4002 having two different bearings. The earlier 5503 types had the platter from the 4000 which had a ball and thrust pad. Yours is the later one which had a lighter but larger black subplatter and only used a centered point. In any case, there does not appear to be anything missing.
3 June 2022 at 11:56 #35234calman65
BRONZE MemberThanks Mark that explains it. I am working my way through Beolovers restored thread. I have yet to hear back from him on this.
3 June 2022 at 12:46 #35235 spassmakerBRONZE MemberHi
Regarding to the confusion about the bearing maybe this gives a bit more light:
https://beolover.blogspot.com/2016/12/beogram-8002-mechanical-adjustments-and-scraping-platter.html
Kind regards
Christian
3 June 2022 at 16:33 #35236 Mark-sfBRONZE MemberChristian, I’m afraid the 8002 had a different bearing yet again as it was a different drive system.
3 June 2022 at 19:19 #35237 chartz
BRONZE MemberThere is a special thrust pad with a hole and the spindle sits slightly over it. Late Beogram 4000´s had the same kind of bearing, only larger (12 mm if memory serves).
3 June 2022 at 19:42 #35238 matadorModeratorI’ve got two 4002 (not 4000’s) and I can’t see what the thrust pads are.
I want to add that one of the BG has a little play in the platter that do not impact playing records.
Can somebody say something relevant about these thrust pads that will not add more haze to the question?
3 June 2022 at 23:00 #35239calman65
BRONZE Membermatador read post#5604., My5513 type 4002 does not use the thrust pad and the “play” in the platter is normal. Its a self centering spindle. During my pre-restore inspection I notice that the zero force balancing screw is loose , just as beolover said it would be .
