Home › Forums › Product Discussion & Questions › BeoGram › Beogram 4000 Speed Issue
- This topic has 4 replies, 2 voices, and was last updated 5 days, 4 hours ago by
Mark Abrahams.
7 August 2025 at 13:31 #68512
Mark Abrahams
SILVER MemberI have a Beogram 4000, it works fine at 33rpm but when its switches to 45rpm, its all over the place i.e. the motor slows down, stops, restarts.
Does have any thoughts on what the fault could be and how to rectify it
Thank you for your assistance.
Kind regards
Mark
7 August 2025 at 14:09 #68515hcraig244
SILVER MemberI would start with the relay that switches between the two speeds….the contacts suffer over time with age, replacements are readily available but will require soldering……it may not be your issue but given the age of these units I would change it out just to eliminate it…..
7 August 2025 at 14:17 #68516hcraig244
SILVER Memberhttps://beolover.blogspot.com/2016/03/beogram-400040024004-relays.html
Rudy above supplies some…they are pricey as they come from the USA, I’m pretty sure I bought some from someone in the UK a couple of years ago…..look around.
Craig
7 August 2025 at 16:49 #68533Mark Abrahams
SILVER MemberThanks for the advice, whereabouts is the relay you’re referring to?
7 August 2025 at 16:55 #68534Mark Abrahams
SILVER MemberThat’s great, thanks. I’ve seen the video so can see what I’m looking for.
