Home › Forums › Product Discussion & Questions › BeoGram › Beogram 3300 – wire pulley making contact with platter wheel
- This topic has 5 replies, 3 voices, and was last updated 1 month, 2 weeks ago by
CharlieWednesday.
1 February 2026 at 14:38 #73019
CharlieWednesday
GOLD MemberHi all
I have a Beogram 3300 that I found was making a noise which worsened as the arm neared the end of the record, so was nearer the centre of the platter. As well as the unpleasant rubbing nose, the speed of playback was being affected.
I’ve looked inside and I’ve found that the pulley for the arm’s wire drive is making contact with the underside of the wheel that sits below the platter, but only when the arm is nearer to the centre of the platter.
I have tried adjusting the platter height with the three screws (as detailed in the service manual), but that raises and lowers the whole thing, so makes no difference to the distance between the wire pulley and the wheel.
Does anyone know if there’s an adjustment I can make to prevent this problem?
5 February 2026 at 19:26 #73274 CharlieWednesday
GOLD MemberFollowing this, out of curiousity I looked inside by Beogram 4500, 8500 and 9500, which I know have essentially the same mechanism. I found in each case that the clearance between the platter wheel and the wire drive pulley is very small – probably 0.5mm if that.
However, on my Beogram 3300, I am still unable to figure out why they are meeting each other when the arm is moved inward. I have been unable to find any way to adjust it.
6 February 2026 at 02:50 #73286 Mark-sfBRONZE MemberCheck that the tonearm measures 53mm above the top of the surface to the top of the arm. Also check with the carriage moved to the center and the platter off that there is 2.5-3mm of between the top of the subchassis and top of the turntable surface all the way around.
7 February 2026 at 09:48 #73341 CharlieWednesday
GOLD MemberThanks for the tip. Yes both of those measurements seem to be right. I had already attempted to adjust the platter height as described in the service manual, but it makes no difference to this specific problem as the whole mechanism is either lifted or lowered, so the distance between the wire drive pulley and the platter wheel remains unchanged.
It’s as if the wire drive pulley is lifting just a little bit as it brings the tonearm to the centre of the platter. It is just about making contact with the underside of the platter wheel. I cannot see any way to increase the height of the platter (independent of the mechanism) or to lower that wire drive pulley.
If I apply a little bit of force to the wire drive pulley while it is making contact, then spin the platter wheel, they come away from each other and the platter wheel moves freely, but once I move the tonearm out and then back in again, the issue instantly returns.
10 February 2026 at 08:51 #73477Dillen
ModeratorReplace the washer under the wire wheel with a thinner type.
11 February 2026 at 06:36 #73525 CharlieWednesday
GOLD MemberThanks Martin – I’ll take a look at the weekend.
