Home › Forums › Product Discussion & Questions › BeoGram › Beogram 3000 Type 5228 – center tap stuck
- This topic has 4 replies, 3 voices, and was last updated 10 months, 2 weeks ago by
soelker.
16 April 2025 at 19:42 #65156
soelker
BRONZE MemberGood evening everyone!
Hope you are doing well prior to Eastern holidays.I recently bought this insanely beautiful Beogram 3000 Type 5228 that needs some service. Therefore I tried to remove the center tap in order to reach to the 3 screws that fix the subplatter.
I probably have to spend more money in the gym than on B&O gadgets as I can not lift this enter tap by any means. I even trie to fix a plastic collar around the tap in order to be able to use a plier without scratching the metal. But the aluminum seems to be rather fragile and I don’t went to bend it.
Any experienced Beogram restaurator who has found a way to remove the center tap? Or is it enough to service just from the underside? The Automatic and tonearm movement seem to need some service.
Thank you very much for your support!
Every idea is very much appreciated!Kindest regards and happy Estern
StefanAttachments:
You must be logged in to view attached files.Location: Düsseldorf, Germany
Favourite Product: Beogram 4002, Beogram 3000 Type 5228, Beomaster 6000
19 April 2025 at 10:19 #65170Dillen
ModeratorPull the spring-loaded part only.
Not the whole round center assy.Martin
21 April 2025 at 14:24 #65222soelker
BRONZE MemberHi Martin,
thank you very much for your reply and try to help!
Yes, I pulled on the upper / inner part of the center tap that sticks out when turning the center tap counter-clockwise to let it pop out through the spring-load. I tried again just the other minute and can’t get it out even with 4 fingers shoving up or two fingers “wrenching” the inner part of the center tap.
The inner spring-loaded part can be turned easily and moves up or down on the spring without any problems. To get completely off the platter spindle though does not work. at least not for me.
EDIT: I just found on the YT channel from UKSUPERRASCAL that the upper / inner part of the center tap contains a washer. Maybe it is stuck to the platter spindle and prevents lifting the inner part up from the spindle?
Anyway, is it possible to fully service the BG 3000 type 5228 from below without removing the subplatter? As I have seen from above the mechanism the idler wheel and belt pulley sits on needs some force to be moved towards and away from the motor spindle. The mechanism is spring loaded, if I understood correctly, and is pulled towards the motor by the main belt that drives the subplatter. So it should move without friction if pulled by hand, right?
May ask 2 more questions while at it:
which lubrication is recommended for the mechanical parts / joints like idler-wheel – belt pulley mechanismen above?
is silicone grease appropriate? Or Molykote DX ?
The service manual does not provide information on thatWhich lubrication is recommended for the motor bearings?
The motor spins freely without belt attached but I assume that motor lubrication is probably gone by now.
Are the pre-oiled bearings / oil reservoirs offered online favourable?Sorry for all these newbie questions. My Beogram service experience is based on Beogram 4002 and to the fantastic, highly recommended blog / YT Channel of beolover.com.
Kindest regards
Stefan
23 April 2025 at 18:27 #65292 matadorModeratorMy experience FWIW…
Removing this part is not easy. To me it belong to the “you must go beyond when you believe you will break it” category.
Pulling it by fiddling with it, slowly and until you “understand” the resistance of the part was my solution. Try it.Then… Removing the platter will of course help you in servicing the deck, but most of the work take place from below.
So depending on what you need to take care of it will not be the big deal.That’s B&O Magic…
24 April 2025 at 10:45 #65297soelker
BRONZE MemberThank you very much for sharing your “fiddling” experience, Matador!
I definitely helps to understand that other people have experienced similar obstacles but succeeded by trying and trying and..I will continue to try pulling the center tap and meanwhile will check the bottom part as well.
BTW for lubricating the idler wheel / belt pulley assembly I have ordered WD-40 White Lithium Grease.
I am unsure about the right oil for the motor bearings.
Gearbox oil for cars should work but are a bit toxic.
Which do you use?Kindest
StefanLocation: Düsseldorf, Germany
