Home › Forums › Product Discussion & Questions › BeoGram › Beogram 3000 Type 5214 signal wiring
- This topic has 4 replies, 2 voices, and was last updated 2 months, 1 week ago by
Mark-sf.
17 January 2026 at 10:56 #72626
Peter8300
BRONZE MemberI have a Beogram 3000 Type 5214 (the one with RIAA socket) that needs rewiring and cleaning up.
It seems like there is more than one way to do it (see pics) but it there one that is best?Attachments:
You must be logged in to view attached files.17 January 2026 at 11:01 #7262817 January 2026 at 20:54 #72662 Mark-sfBRONZE MemberI’m not sure I understand your question. The solder connections all look sound. By rewiring are you planning to replace the wire? These are simply terminals so as long as they match the other side’s wiring the order doesn’t matter.
18 January 2026 at 16:27 #72692Peter8300
The turntable hums, so I plan to remove all wires, clean everything up an re solder everything back hoping that that will take care of it.
18 January 2026 at 23:48 #72700 Mark-sfBRONZE MemberWhile that type of maintenance is great to do, it will not likely solve your hum problem. Hum is typically caused by improper grounding between the turntable chassis and the receiver/preamp. The wires shown in your picture are the signal wires. The ground wire will be separate to the ground screw if you are using RCA phono connectors and its connected to the shield of the internal side of a DIN cable. If you still can’t find it, please post pictures of both ends of your turntable output cable and its connections.
