Home › Forums › Product Discussion & Questions › BeoGram › BeoGram 2400
- This topic has 4 replies, 2 voices, and was last updated 1 year, 11 months ago by
Dillen.
28 February 2024 at 02:46 #53098
Bookworm
BRONZE MemberDear Fell0w B & O Enthusiasts,
I am putting an old Beogram 2400 back into service. I have made the mistake of taking off the lid in order to remove the accumulated scratches. After doing that I have been able to restore the lid beautifully. On the down side I am totally unable to figure out how to replace the lid, I have all the parts so I presume it is a fairly simple operation.
If anyone can provide me with a step by step guide or point me in the right direction to where i can find the information to do this i would be very grateful. The service manual although showing a schematic image of the lid/hinge mechanism does not show enough detail for me.
Thank you Bookworm
28 February 2024 at 17:33 #53099Dillen
ModeratorRead my post in this thread:
https://forum.beoworld.org/forums/topic/beogram-1902-dust-cover/
28 February 2024 at 19:55 #53100Bookworm
BRONZE MemberHi Dillen, Thank you so much for your very prompt and informative reply. I will certainly give this a go. I am a bit concerned that I might break something but your easy to follow steps gives me confidence.
Thanks, Bookworm.
4 March 2024 at 14:35 #53101Bookworm
BRONZE MemberHi Martin, Just a quick update, I did this yesterday following your instructions to the letter and pleased and relieved to say all went well.
I was really apprehensive as I did not want to break the lid. I must say the long thin spring is REALLY strong when “wound” up. Many thanks again. Ken. (Bookworm)
4 March 2024 at 22:17 #53102Dillen
ModeratorGood job, and thanks for the feedback!
