Home › Forums › Product Discussion & Questions › BeoGram › beogram 2200 motor problems
- This topic has 3 replies, 2 voices, and was last updated 1 year, 2 months ago by
Dillen.
30 December 2024 at 22:01 #62076
Marc Verheijen
BRONZE Memberi’ve bougt a beogram 2200. it doesnt run. I took the disk of. when i get the power on i saw a little movement but nothing more. when i get the belt of and puts the power on the motor just spins for a second, 3 or 4 turns and then stops. the lioghts are on and all but the motor doesnt turn. when i get power off and then on again it repeats again and again: the motor turns for only 3 a 4 spins and then stops
any suggestion is more then welcome. what could be the issue? What can i do?
1 January 2025 at 16:04 #62151Dillen
ModeratorRecord on the platter?
1 January 2025 at 22:53 #62164Marc Verheijen
BRONZE Memberhi martin
yes, also with a record on the platter it has the same issues
electricity is ok
when i turn the platter by hand, the beogram proces for staring and stopping works perfectly
only problem, the motor doesnt spin
2 January 2025 at 07:45 #62168Dillen
ModeratorCheck the start switch. These switches are known to oxidize and lose contact, particularly if not used for a long time.
Check for cracked solder joints where connectors are soldered to the circuit board.
All OK? Check voltage on motor leads.Martin
