Home › Forums › Product Discussion & Questions › BeoGram › Beogram 2000 (5244) Speed changer issues
- This topic has 6 replies, 2 voices, and was last updated 2 years ago by
RIB2906.
27 February 2024 at 05:15 #53085
RIB2906
BRONZE MemberHi everyone, Does anyone know if the speed changer mechanism for a Beogram 2000 type 5244 is available anywhere as a spare part? My almost 30 year old deck is grinding away and the speed changer arm seems to be the problem. I’d really appreciate your help. Thanks!
(Title edited to read Beogram 2000 rather than Beogram 200) Dillen
27 February 2024 at 18:11 #53086Dillen
ModeratorYou don’t replace it – it must be taken apart, cleaned and lubricated. It can all seize up
in dry lubricants.
New idler wheel, new lifting arm friction pad and a new belt.
The motor will almost surely also need new bearings in order to run correctly.
All of these parts are available.Martin
27 February 2024 at 22:21 #53087RIB2906
BRONZE MemberHi Martin, thanks for the advice. May I ask for your help with two things please? Any idea where I can source the parts? Secondly is there a recommended lubricant? Many thanks, Richard.
28 February 2024 at 07:30 #53088Dillen
ModeratorI like to use a teflon-based oil called “Liquid bearing”, but any good long-term oil or light grease would be fine.
Parts here.
28 February 2024 at 16:53 #53089RIB2906
BRONZE MemberThat’s really helpful – thank you!
I had the motor replaced a couple of years ago so I think that should be fine but I have noticed the re-assembly of the parts was wrong with inversion of Spacers causing some impacts which I have now fixed. I don’t have the service manual so may I ask for your assistance with one more question please? Please see the attached image from Beoparts of the idler wheel underside. My question is should the end of the lifter arm fit into the slot in the side of the brass bush or does the brass bush sit on the idler arm held in place by gravity? In the slot appears to make more sense.
Many thanks,
Richard
28 February 2024 at 17:34 #53090Dillen
ModeratorThe lifter arm with the small pad should work in the groove, so it can lift and lower the wheel.
28 February 2024 at 17:54 #53091RIB2906
BRONZE Member- Thank you very much Martin. That confirms what I thought it should be. I’ve ordered a replacement small pad as it is missing. Possibly disintegrated. Thanks again. Much appreciated.
- Richard
