Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1600 cartridge adjustment
- This topic has 8 replies, 4 voices, and was last updated 2 years, 10 months ago by
omminp.
11 May 2023 at 11:49 #46542
Arrontd
BRONZE MemberHi
Could you help with the 3 screws in the arm , not sure which one you use for adjustment.
11 May 2023 at 18:00 #46543 Mark-sfBRONZE MemberNot sure which adjustment you are seeking. Take a look at this service manual for all. https://beomanuals.com/manuals/Beogram/Beogram%202400/Bang-Olufsen-Beogram_2400-Service-Manual.pdf
11 May 2023 at 18:49 #46544Dillen
ModeratorAdjustment of what?
11 May 2023 at 20:50 #46545Arrontd
BRONZE MemberArm does not go down onto record
12 May 2023 at 04:11 #46546 Mark-sfBRONZE MemberThat could be multiple adjustments. Go through the adjustments detailed in the above service manual.
12 May 2023 at 13:05 #46547Arrontd
BRONZE MemberThanks
Part 177 and 171412 May 2023 at 13:08 #46548Arrontd
BRONZE MemberHi
Just got this Beogram 1600
No sound when playing , very odd has last owner said it was ok ?
12 May 2023 at 23:30 #46549 Mark-sfBRONZE MemberHow are you connecting it? Type of cable – DIN or RCAs? Phono Input on what component?
15 May 2023 at 08:25 #46550omminp
SILVER MemberFrom the photo, it looks like it is missing the counterweight. That needs to be in place so the arm can be balanced….
