Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1500 Model 5714
- This topic has 3 replies, 3 voices, and was last updated 2 months ago by
Dillen.
28 January 2026 at 14:08 #72909
Wojciech Herchel
BRONZE MemberHi all,
I just got the said model, it does seem to work fine, the only issue is that I wasn’t able to figure out how to play 12″ at 45rpm… as if I put a record on and press 45, the arm moves to the 7″ inch position. I tried hitting pause and then moving it to the initial groove (already not ideal) and then pressing 45 again, but it goes back to the 7″ start position…
12″ at 33rpm play fine, tried pressing 33rpm and then 45rpm but again it goes to 7″ start…
any ideas what could be wrong?
28 January 2026 at 16:39 #72917 Mark-sfBRONZE MemberNothing is wrong with it as that’s the way it was designed. There were no 12” 45’s in its time.
28 January 2026 at 17:00 #72918Wojciech Herchel
BRONZE Memberso nothing can be done?
28 January 2026 at 18:09 #72922Dillen
Moderator45RPM is not a standard for 12″ records.
Start the Beogram at 45, catch the tonearm as it lowers and manually feed it back to the lead-in groove.Martin
