Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1202
- This topic has 2 replies, 2 voices, and was last updated 3 years, 11 months ago by
TomDelgado.
8 May 2022 at 04:00 #34709
TomDelgado
BRONZE MemberDear all, my Name is Thomas and a write from Italy.
I sadly have an issue with my beloved beogram 1202, the tonarm goes down far before the first groove of the Lp.
Can someone please explain me how to regalate that?
Thanks and have a nice day.
Thomas
9 May 2022 at 03:59 #34710 Mark-sf
BRONZE MemberIn the bottom cover there are two holes that adjust the set down point for 7” and 12” records. It is easiest to place it on a stand or supports so that you can watch the arm without having to constantly flip it. If your bottom does not have the holes then you will need to remove the 4 corner screws and remove it first. These eccentrics should be marked and are in the from of the cam gear.
9 May 2022 at 06:18 #34711TomDelgado
BRONZE MemberThank you Mark!
I’ll try later in the afternoon and hope not to cause any damage?
Have a nice day!
