Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1102 tone arm return height.
- This topic has 1 reply, 2 voices, and was last updated 1 day, 23 hours ago by
Peter Fraser.
24 June 2025 at 21:12 #66627
Mark Smith
BRONZE MemberHi all, my Beogram 1102 generally works like a champ but I’d like to use a thin (1mm) slip mat. Problem is the tone arm doesn’t lift high enough to allow for this. When returning on a 180g disc (without a slip mat), it barely lifts high enough to clear the surface. So my question, is there a way to adjust how high the tone arm lifts?
25 June 2025 at 12:04 #66639Peter Fraser
ModeratorHello Mark,
You can adjust the pickup height.
The process is explained in the service manual.
BeoGram 1102 – BeoworldWhen returning on a 180g disc (without a slip mat), it barely lifts high enough to clear the surface
I believe the grease within the lift mechanism may have become viscous.
I would also recommend cleaning and regreasing if possible.Kind regards,
PeteSignature: Peter Fraser
Service Technician
Multicare Electronics -
