Home › Forums › Product Discussion & Questions › BeoGram › Beogram 1102 tone arm return height.
- This topic has 2 replies, 2 voices, and was last updated 9 months, 1 week ago by
Mark Smith.
24 June 2025 at 21:12 #66627
Mark Smith
BRONZE MemberHi all, my Beogram 1102 generally works like a champ but I’d like to use a thin (1mm) slip mat. Problem is the tone arm doesn’t lift high enough to allow for this. When returning on a 180g disc (without a slip mat), it barely lifts high enough to clear the surface. So my question, is there a way to adjust how high the tone arm lifts?
25 June 2025 at 12:04 #66639Peter Fraser
ModeratorHello Mark,
You can adjust the pickup height.
The process is explained in the service manual.
BeoGram 1102 – BeoworldWhen returning on a 180g disc (without a slip mat), it barely lifts high enough to clear the surface
I believe the grease within the lift mechanism may have become viscous.
I would also recommend cleaning and regreasing if possible.Kind regards,
PeteSignature: Peter Fraser
Service Technician
Multicare Electronics30 June 2025 at 21:55 #66742Mark Smith
BRONZE MemberHi Pete,
Many thanks for that – dead easy in the end and my playing enjoyment has been transformed!
Next question, is it possible to adjust where the needle lands on the record? It sometimes “falls off the edge”.
Mark
