BeoGram 1000 Pre-Amp PCB: what are the dimensions?
Home Forums Product Discussion & Questions BeoGram BeoGram 1000 Pre-Amp PCB: what are the dimensions?
Viewing 9 posts - 1 through 9 (of 9 total)
  • #36652
    KolfMAKER
    I am trying to recreate the original Pre-Amp PCB for the BeoGram 1000.
    So far, I have the images of the copper traces, including a drawing of the placement of the components and the specs of those. Now I only need to know the exact dimensions of the original Pre-Amp PCB board.
    Question
    Who can help me find the dimensions. In the picture below I have marked the dimensions I am looking for: A – E.
    Schermafbeelding 2022-08-05 om 10.02.50
    mexking
    Dimensions all mm.
    BG 1000 prea
    #36654
    matador
    THIS IS GOOD BEOWORLD !!!
    #36655
    KolfMAKER
    @Mexking
    This is perfect information, thanks so much !!!
    I will start to re-produce the original BeoGram RIAA preamp.
    Fantastic!
    KolfMAKER
    At the moment I am in preparation of making the PCB. My first step is to get the copper traces on a board.
    Therefor I have to position and size the image of the copper traces perfectly. I have that picture (see picture below), but it has no outer/PCB border lines, so I have to find out how to size and position this image. (Obviously to get size and proportion equal to the original PCB)
    Questions
    1. Does anyone have such picture of the copper traces pattern, including outside/PCB border lines?
    2. @Mexking: do you have a picture of the bottom side of the pre-amp board?
    mexking
    Your trace pic is view from component side, here my pic from solder side, black dots are ground (neg.) connections
    20220808_130204
    #36658
    KolfMAKER
    @Mexking
    Thanks for sending the bottom view picture!
    Yes, I am aware that my trace image has to be mirrored.
    Question
    The board side that sticks into the slot (so where the 8 tracks in a row are), has 8 notches.
    Can you please let me know how deep they are?
    I think they are a little less deep than the 6mm notch on the other side of the board.
    mexking
    Notches 2.5 mm
    #36660
    chartz
    In fact the small PCB in the Beogram sans  phono board has the same notches. Just remove it to see!
