Home › Forums › Product Discussion & Questions › BeoGram › BEOGRAM 1000 motor gets hot
- This topic has 1 reply, 2 voices, and was last updated 3 years, 3 months ago by
chartz.
2 January 2023 at 03:45 #42019
RogerL
BRONZE MemberMy BEOGRAM 1000 works very well but the motor gets hot – is this normal?
I had to put something under the turntable to protect the wooden cabinet the unit stands on because of the hot motor.
Please advise
Many thanks
Roger
2 January 2023 at 17:02 #42020 chartzBRONZE MemberHi Roger,
It does get hot but not burning hot. Are you sure it runs smoothly (lubrication) and that you have the correct speed right away? Did you have to increase pitch adjustment to its end stop? Do you have the original belt?
